Palettes and Tool Sets
The workspace contains various palettes for creating and editing objects. Depending on the initial settings, some palettes may be hidden when the program is launched. You can customize which palettes display and where they are placed for each workspace.
●    Select Window > Palettes > [palette name] to display or hide palettes. Alternatively, right-click on the drawing area, and select Palettes > [palette name] from the document context menu.
●    Click the title bar of any displayed palette and drag it to the desired location.
●    Most palettes can be resized by the standard Windows or Mac resize method.
●    Palettes can be docked to the application window (see Docking Palettes).
Each time you exit the Vectorworks program, the current palette settings and positions are automatically saved for each workspace in a file in your user folder ([User]\Settings\SavedSettings.xml). The settings in this user file override the initial palette settings in the workspace file. To reset to the original workspace settings, click Reset Saved Settings from the Vectorworks Preferences: Session Tab.
Palette / Tool Set
Purpose
Snapping
Contains SmartCursor snapping controls that can be toggled on or off; see Setting Snapping Parameters
Attributes
Contains a selection of colors, fills, pens, and other object attributes; see The Attributes Palette
Object Info
Lists context-sensitive object information for viewing and editing; see The Object Info Palette
Working Planes
Contains controls for adding and modifying working planes; see The Working Planes Palette
Resource Manager
Accesses and manages the resources available for use in drawings, such as hatches, record formats, worksheets, scripts, symbols, textures, and more. See Resource Manager.
Navigation
(Design Series required)
Provides access to classes, design layers, sheet layers, viewports, and saved views, while the drawing area remains accessible; see The Navigation Palette
Visualization
Accesses all lights and cameras in the file; see Managing Lights and Cameras with the Visualization Palette
Script Palettes
Contains palettes with script resources; see Creating and Editing Script Palettes and Scripts
Tool Palettes
The Basic palette and Tool Sets palette have special functionality, as described in Tool Palette Features
Basic
Contains a single set of basic object creation and editing tools; the palette can be customized through the Workspace Editor. The Basic palette contains different tools in different workspaces.
Tool Sets
Depending on the workspace, this palette includes the following tool sets, whose tools are grouped by similar functionality; the palette and its tool sets can be customized through the Workspace Editor. Each tool set may contain different tools in different workspaces.
Site Planning
(Architect or Landmark required)
Contains tools for site planning and landscape architecture
Space Planning
(Architect required)
Contains tools for space planning and programming buildings
Irrigation
(Landmark required)
Contains tools for irrigation system design
Spotlight
(Spotlight required)
Contains tools for lighting and event design
Building Shell
Contains tools for creating building shell elements
3D Modeling
Contains tools for creating and editing 3D objects, including solids and NURBS
Visualization
Contains tools for changing the drawing view in different ways
Furn/Fixtures
Contains tools for creating common furniture and fixtures
Dims/Notes
Contains tools for adding dimension and label objects
Walls
(Fundamentals workspace only)
Contains basic wall creation tools
Detailing
Contains tools for adding architectural detail objects, such as tubing
MEP
Contains tools for mechanical, electrical, and plumbing design
Fasteners
Contains tools for inserting a variety of fasteners such as nuts, bolts, pins, and screws
Machine Components
Contains tools for inserting machine components such as gears, bearings, and springs
Palette Display Options
Saving Palette Positions and Settings
Application Window
Modifying Menus and Commands
