Select the collar style; flush collars
or collar ties will only connect to the common rafters,
joist collars connect to both common and jack rafters
●Joist: tie beam that rests
on the bearing wall and overlaps the rafters
●Flush Collar: tie collar that
is flush to the rafters, usually attached to the rafters
with metal plates
●Collar Tie: tie collar that
scabs onto the rafters and is attached with nails, bolts,
and so on
Size
Specifies the collar size in width
x height, in current file units. Sizes can be edited by
selecting Edit List (see
Custom Frame Element Sizes).
Spacing
Select the collar spacing (Every
Rafter, Every Other Rafter, and Every Third Rafter)
Location
For joist or collar tie styles, specifies
the location of the collars in reference to the rafters.
For flush collar style, the location is automatically
set to Middle.
●Middle places one collar at
the center of the rafter for flush collar and joist styles,
and one collar on each side of the rafter for the collar
tie style
●Left/Right places a single
collar on the designated side of the rafter for joist
or collar tie styles. Joists and collar ties extend to
the intersection of the rafter tops.
Elevation AFF
Specifies the elevation above finished
floor of the bottom of the collars. If Flush Collar or
Collar Tie is selected for Style,
the default elevation is two-thirds of the roof height.
Joist style is automatically set to 0.
Class
To control appearance and visibility,
select a class from the list of classes present in the
drawing or create a new class (see Creating Classes)
