Specifies the purlin size in width
x height, in current file units. Sizes can be edited by
selecting Edit List (see
Custom Frame Element Sizes).
Elevation of First Purlin
Specifies the elevation above finished
floor of the bottom of the lowest purlin
Elevation of Last Purlin
Sets the elevation from the top of
the roof to the last purlin
Create Purlins by:
Number of Purlins
Indicates the number of purlins to
create; the purlins are evenly spaced between the first
and last purlins
Distance Between Purlins
Specifies the distance between purlins;
the number of purlins created is based on this value
Purlin Position
Top of Rafter
Matches the tops of the purlins to
the top of the roof object, as for roof tile supports
Bottom of Rafter
the bottom of the roof, as when the purlins support the
rafters
Purlins Start at the Lower End of
the Rafter
Sets the elevation of the first purlin
to start from the lower end of the rafter
Rotate Purlins to Roof Slope
Rotates the purlins so that they
match the slope of the roof
Bearing inset
Specifies the depth at which the
purlin is notched into the rafters; if purlins are rotated
this field is grayed since the inset only applies to horizontal
purlins
Class
To control appearance and visibility,
select a class from the list of classes present in the
drawing or create a new class (see Creating Classes)
