Rectangular Tubing
To create rectangular tubing:
  1. Click the Rectangular Tubing tool from the Detailing tool set.
  2. The Rectangular Tubing tool and Rectangular Tubing - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
  3. Click to place the object in the drawing, and click again to set the rotation.
Structural Shapes and Details
