DesignSeries00078.pngZ-Section
To create a  Z-section object:
  1. Click the Z-Section tool from the Detailing tool set.
  2. The Z-Section tool and Z-Section - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
  3. Click to place the object in the drawing, and click again to set the rotation.
Structural Shapes and Details
