Editing Plug-in Object Styles
Editing a plug-in object style changes every instance in the file that uses that style.
To edit a plug-in object style:
  1. Open the <Object> Style dialog box or Plug-in Object Style dialog box in one of these ways:
  2. ●    In the drawing area, right-click on a plug-in object that uses the style to edit, and select Edit Plug-in Style from the context menu.
    ●    From the Resource Manager, right-click on the style to edit, and select Edit from the context menu.
    ●    From the Object Info palette, select Edit Style from the Style list.
  3. Set the parameters as described in Creating Plug-in Object Styles.
