Moving Symbols in Walls with the Move Command
Symbols or plug-in objects within a single wall can be moved with the Move command.
To move one or more symbols in a wall:
  1. Select the symbol to move; if multiple symbols are selected, they must be in the same wall.
  2. Select Modify > Move > Move.
  3. The Move Selection dialog box opens. The fields available depend on whether the wall that contains the selected symbol is straight or round.
  4. Click OK, and the symbols are moved as specified.
Moving Symbols in Walls with the Selection Tool
Moving Symbols in Walls with the Move by Points Tool
Symbols Within a Wall
