Setting a 3D View
The Set 3D View command sets a precise 3D view at a specified viewing angle, height, and perspective. Normally, the command is executed from 2D Top/Plan view; however, the command can also set a 3D view from any of the 3D views.
To set a 3D view:
  1. Select View > Set 3D View.
  2. Click and draw a line to indicate the view direction; the line starting point indicates the viewer position and the line end point indicates the point the viewer is looking towards (look toward point).
  3. The Set 3D View dialog box opens.
  4. Specify the 3D view criteria.
  5. Click OK. The 3D view is adjusted as specified.
Placing a Camera View
