DesignSeries00036.pngReplacing Wall Styles from the Object Info Palette
Wall styles applied to existing walls or curtain walls can be replaced with a different wall style.
A wall replacement situation may also occur if pasting a styled wall from another file. You can select a replacement wall style and specify how to align the styles for the pasted walls.
To replace a wall style:
  1. Select one or more walls.
  2. From the Object Info palette, select Replace from the Style list.
  3. The Wall Replacement dialog box opens. Specify the new wall style and the alignment options.
    If walls with different wall styles were selected for replacement, the current wall preview is blank and components are not listed. Wall alignment can only occur for the left, center, or right of the selected walls.
  4. Click OK to replace the wall style of the selected wall.
Deleting and/or Replacing Wall Styles from the Resource Manager
Creating Wall Styles
Applying Wall Styles
