DesignSeries00080.pngSetting Curtain Wall Panel Parameters
The panel settings and appearance are specified in the Panel Settings dialog box.
If setting up curtain wall preferences, these parameters are available from the Definition tab of the Wall Preferences dialog box. For an existing curtain wall, they are available from the Curtain Wall Grid dialog box.
To set the curtain wall panel appearance:
  1. From the Object Info palette of a selected curtain wall, click Curtain Wall Grid.
  2. The Curtain Wall Grid dialog box opens.
  3. Click Panel Settings.
  4. The Panel Settings dialog box opens.
  5. Click OK.
Creating Curtain Walls
Editing Curtain Walls
Applying Object Attributes
Assigning IFC Data to Objects
