Spot00047.pngAdding Loads
The Insert Load tool is located in the Rigging tool set.
Many Spotlight objects are automatically considered to be either a point load (such as lighting instruments, projectors, and speaker arrays) or a distributed load (such as soft goods, video screens, and LED screens). A generic point load or distributed load can be added with the Insert Load tool.
After placement, the generic load symbol can be switched to use a realistic graphical symbol instead.
The following modes are available.
Mode
Description
Point Load
Inserts a point load
Distributed Load
Inserts a distributed load
Load Category
Specifies the load category, which is important for calculations (Braceworks required)
Weight
Sets the weight of the load. For a point load, this value is the total weight. For a distributed load, this value represents either the weight or the distributed weight, depending on the selected weight mode.
Non-Rotated Label
(point load only)
Does not rotate the label text
Perpendicular Label
(point load only)
Angles the label text 90 degrees from the structural element
Angled Label
(point load only)
Angles the label text 45 degrees from the structural element
Distributed Weight Mode
(distributed load only)
For distributed loads, the specified Weight represents the distributed weight
Total Weight Mode
For distributed loads, the specified Weight represents the weight
Load Settings
Opens the Load Settings dialog box, for creating and selecting saved load sets
Creating and Selecting Load Sets
Inserting a Point Load
Inserting a Distributed Load
