DesignSeries00018.pngODBC Driver Information
When setting up a database program for ODBC functionality, related drivers may not be installed. This list describes drivers available for each platform, where to obtain them, and current problems that may exist.
SQLite database files do not require an ODBC manager.
Windows
On Windows, the ODBC manager is integrated into the operating system (OS).
Driver Name
Driver
Driver Connection
Update Vectorworks records by reading data from database
Update database with Vectorworks record data
Add new database table rows through object connection
Microsoft Access
Integrated in the OS
Supported, working
Supported, working
Supported, working
Supported, working
Microsoft Excel
Supported, working
Supported, working
Supported, working
Supported, working
Microsoft SQL Server
If not integrated in the OS, ask vendor
Supported, working
Supported, working
Supported, working
Supported, working
Microsoft Text Driver
Supported, working
Supported, working
Supported, working
Supported, working
MySQL
Available at:
mysql.com
Supported, working
Supported, working
Supported, working
Supported, working
FileMaker Pro *
Available at:
filemaker.com
Supported, working
Supported, working
Supported, working
Supported, working
* As of its version 12, FileMaker Pro includes the driver needed to share your database as a data source. To use your FileMaker database file locally, FileMaker Pro must be running, and the database file opened and shared. To share your FileMaker database file as a data source over a network, use FileMaker Server Advanced. As of version 13 of FileMaker Pro, the ODBC driver is distributed with the server version of the product. For more details, see filemaker.com.
Mac
On the Mac, there is no integrated ODBC manager. Suggestions include:
●        ODBC Manager (odbcmanager.net)
●        iODBC Manager (iodbc.org)
●        ODBC Administrator Tool (support.apple.com/kb/DL895)
Driver Name
Driver
Driver Connection
Actual SQL
Available at:
actualtech.com
Supported, working
Supported, working
Supported, working
Problem reported: data length restriction when writing to database
Supported, working
Actual Access
Available at:
actualtech.com
Supported, working
Not supported
Not supported
Not supported
MySQL
Available at:
mysql.com
Supported, working
Supported, working
Supported, working
Supported, working
FileMaker Pro *
Available at:
filemaker.com
Supported, working
Supported, working
Supported, working
Supported, working
Database Setup
