Mode |
Tool |
Tool set |
Modes for The Symbol Insertion Tool |
Hole - Drilled
Detailing |
Multiple drilled and tapped hole tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Both 2D and 3D drilled holes are available. The 3D drilled hole is a solid object that can be subtracted from any other solid object to create accurate 3D models of molds, dies, and many other machine parts (see Subtract Solids).
To insert a drilled hole:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation.
Click
to show/hide the parameters.
