Angle Between Two Object Edges or Faces
Mode
Tool
Workspace: Tool set
Edges
Angular Dimension
●        Fundamentals, Architect: Dims/Notes
●        Landmark, Spotlight: Basic and Dims/Notes
To dimension the angle between the edges or faces of two objects:
  1. Click the tool and modes, and then select a Dim Std (dimension standard).
  2. Click the edge or face of the first object.
  3. A preview line displays.
  4. Click the edge or face of the second object.
  5. An angular dimension preview displays.
    To select a different angle—for example, spanning the opposite direction—move the cursor until the preview displays the desired angle.
  6. Click a third time to define the radius of the dimension.
Angular Dimensioning
Editing Dimensions
