Arc Length Dimensioning
Tool
Workspace: Tool set
●        Fundamentals, Architect: Dims/Notes
●        Landmark, Spotlight: Basic and Dims/Notes
The Arc Length Dimension tool measures and dimensions the length of an arc anywhere along its circumference. The dimension can be shown with its witness lines perpendicular to a chord on the arc, or perpendicular to a line tangent to the arc. There are also modes to hide or show a graphic of an arc over the dimension measurement.
This tool works with arcs, polylines that include arc segments, arc-based 3D objects, and round walls. It always creates the dimension on the same plane as the arc that is being dimensioned.
Mode
Description
Witness Lines Perpendicular to Chord
Dimensions the arc with witness lines that would be perpendicular to a chord drawn across the arc
Witness Lines Perpendicular to Tangent
Dimensions the arc with witness lines that would be perpendicular to a line drawn tangent to the arc
Arc Indicator Visible
Displays an arc graphic over the dimension measurement
Arc Indicator Invisible
Uses a dimension measurement with no arc graphic
Dimension Standards
To change the dimension standard for new dimensions created in the document, select a standard from the list; select Custom Standards to create or manage custom dimensions (see Using Custom Dimension Standards)
To create an arc length dimension:
  1. Click the tool and applicable modes, and then select a Dim Std (dimension standard).
  2. Click to set the measurement start point.
  3. Click to set the end of the measurement.
  4. Move the cursor away from the object.
  5. This specifies how far the dimension line is offset from the measured object.
  6. Click to place the dimension line.
Editing Dimensions
Associative Dimensioning
