Measuring in Degrees
The Protractor tool measures angles in the drawing, and temporarily displays the degrees measurement in the Data bar. There are two modes for the tool.
Mode
Description
Angle from Two Segments
Calculates the angle between two objects or object sides that are linear—rectangles (including rounded and rotated), lines, polylines, and polygons. This mode cannot measure circles, ovals, or arcs, and it cannot measure between parallel lines.
Angle from Three Points
Measures an angle between three points in the drawing area
Angles Between Objects or Object Sides
Mode
Tool
Workspace: Tool set
Protractor
●        Fundamentals, Architect: Dims/Notes
●        Landmark, Spotlight: Basic and Dims/Notes
To measure the angles between objects or object sides:
  1. Click the tool and mode.
  2. Move the selection arrow over the first side of the angle to measure.
  3. Click to select the side, and then move the cursor to the other angle side.
  4. The angle displays in the Data bar.
  5. Note the angle, and then click to end the measurement.
Angles Between Three Points
Mode
Tool
Workspace: Tool set
Protractor
To measure angles between three points:
  2. Click to set the first point.
  3. Click to set the second point.
  4. Move the cursor to the third angle point.
  6. Note the angle, and then click to end the measurement.
Measuring Distance
