Inserting
an LED Screen Mode |
Tool |
Tool set |
Modes for The Symbol Insertion Tool |
LED Screen
Event Design |
The Light-emitting Diode (LED) object simulates a variety of low-resolution LED screens in arrays on a base structure.
To insert an LED screen or array:
Click the tool and the desired insertion modes.
Click to place the object in the drawing, and click again to set the rotation.
Click
to show/hide the parameters.
Parameter |
Description |
Module Shape |
Select a shape for the screen modules in the array
Tile Flat |
Creates rectangular-shaped modules |
Tile Cap |
Creates rectangular-shaped modules with frosted caps |
Disk Flat |
Creates round modules |
Disk Cap |
Creates round modules with frosted caps |
Tube |
Creates tube-shaped modules |
Dome |
Creates dome-shaped modules |
Width |
Specifies the width of each module in the array |
Height |
For tiled arrays, sets the height (length) of each module in the array |
Cap Depth |
For capped arrays, sets the depth of each module’s cap |
Tube Orientation |
For tube arrays, specifies whether the tubes are oriented vertically or horizontally |
Length |
For tube arrays, sets the length of one of the tube modules |
Build Array Based On |
Module Counts and Spacing |
Sets the size of the entire LED array based on the number of modules specified in the horizontal and vertical directions, as well as the horizontal and vertical spacing distance set between the modules |
Overall Dimensions and Spacing |
Sets the size of the entire LED array based on the specified array width and height, as well as the horizontal and vertical spacing between the modules; the screen count is automatically calculated |
Overall Dimensions and Module Counts |
Sets the size of the entire LED array based on the specified array width and height, as well as the number of modules specified in the horizontal and vertical directions; the spacing is automatically calculated |
Array Width/Height |
Specifies the width and height of the entire LED array, when the array is based on overall dimensions |
Horizontal/Vertical Spacing |
Specifies the spacing between modules in the horizontal and vertical directions, when the array is based on spacing parameters |
Horizontal/Vertical Count |
Specifies the number of modules in the horizontal and vertical directions, when the array is based on the module counts |
Module Total |
Displays the total calculated number of modules in the array |
Width/Height (Calc.) |
Displays the calculated width and height of the array, when determined by module count and spacing |
H/V Spacing (Calc.) |
Displays the calculated module spacing in the horizontal and vertical directions, when the array is determined by the overall dimensions and module counts |
H/V Count (Calc.) |
Displays the total number of modules in the horizontal and vertical directions, when the array size is determined by the overall dimensions and module spacing |
Pixels Per Module H/V |
Specifies the number of horizontal or vertical pixels for each module (for calculation purposes only; does not affect the module display) |
Array Size (Pixels) |
Displays the total number of pixels for the entire LED array |
Array Aspect |
Specifies the aspect ratio of the array |
Base Structure |
Select a base structure for the array; modify the appearance of the structure by selecting Class LED Array Parts and then editing the structure class
Blocks |
Creates a structure of individual blocks bases for each module |
Frame |
Creates a single frame for the entire array |
Curtain |
Creates a single background for the array |
Web |
Creates a webbed structure behind the modules |
Vert. Strips |
Places the LED modules in vertical columns |
Horiz. Strips |
Places the LED modules in horizontal rows |
None |
Does not create a base structure for the array; displays only the LED modules |
Base Width |
Specifies the width of blocks, vertical or horizontal strips, or the entire frame |
Base Height |
Specifies the height of blocks, vertical or horizontal strips, or the entire frame |
Base Depth |
Specifies the depth of blocks, vertical or horizontal strips, or the entire frame |
Horizontal Inset |
Sets the horizontal distance (margin) between the horizontal edge of the base structure and the array |
Vertical Inset |
Sets the vertical distance (margin) between the vertical edge of the base structure and the array |
Pleat Width |
For curtain or web structures, specifies the pleat width of the curtain (2D only for web structures) |
Pleat Depth |
For curtain or web structures, specifies the pleat depth of the curtain (2D only for web structures) |
Webbing Width |
For web structures, sets the width of the connecting web segments |
Tilt |
Specifies the tilt angle of the screen array |
Simple 3D |
Creates a single textured 3D polygon to represent the screen modules; this speeds rendering when each module does not need to be shown individually |
Edit Array Image |
Opens the Edit Screen Image dialog box |
Array Image |
Displays the name of the current screen image |
Wattage |
Enter the required wattage, for power consumption calculations and reporting |
Note |
Adds a note, which can be placed in the drawing with the Text Options |
Text Options |
Opens the Text Options dialog box, to enable the display and format the text of labels |
Default Text Positions |
Restores text labels to their default positions |
Opens the Classes dialog box, to specify class naming for the various portions of the LED screen. This allows portions of the LED screen to be set to visible, grayed, or invisible. Use the suggested standard class, select a class from the list of classes present in the drawing, or create a new class. Select <LED Screen Class> to place the LED screen element in the same class as the LED screen. ● Class Prefix: Specifies an optional default root class naming standard for all LED screen parts; click Use Standard Classes to begin all LED screen class names with the prefix, so that they are sorted together. ● Use Standard Classes: Sets the class names for all LED screen elements to the default suggested standard names, using the Class Prefix if there is one. ● LED screen elements: For each portion of the LED screen, specifies the class name standard; the class names shown here are applied to the elements. |
Update |
Updates the object when changes have been made to the Object Info palette parameters |
Load Information |
An LED screen is considered a distributed load in Braceworks calculations; if the screen is inserted parallel to a structural element, it is considered to be a load on that structure. Load information is used for Braceworks calculations and reports (Braceworks required). |
Include in Calculations (Braceworks required) |
Includes the LED screen in Braceworks calculations; deselect to exclude the object from participating in structural calculations |
Load Group Name |
The load category is always Video for LED screen objects |
Load ID |
Enter a unique ID for the load for informational use in reports |
Load Name |
Identifies the object in load calculations |
Distributed Weight |
Enter the distributed weight of the LED screen object; changes here also affect the Total Weight value |
Total Weight |
Enter the total weight of the object |
Setting the Image on the Video Screen
Formatting Video Screen Object Labels
Associating Load Objects with a Hanging Position
