Editing
DrainsMode |
Tool |
Tool set |
Edit |
Slab Drainage
Building Shell |
Drains can be edited and deleted using context menu commands that are available when the Slab Drainage tool is selected.
To edit drain properties:
Select the slab object.
Click the tool and mode.
Right-click on one or more drains and select Edit Drain(s) from the context menu.
The Drain Settings dialog box opens.
Set the properties.
Click
to show/hide the parameters.
To delete a drain:
Click the Slab Drainage tool.
Right-click on one or more drains and select Delete from the context menu.
