DesignSeries00044.pngEditing Slab Geometry with 2D Modifiers
Adding a 2D Shape to the Slab Surface
When adding to a slab, select whether the add operation should affect the entire slab or only certain components.
To add a 2D shape to a slab:
  1. Create a closed 2D shape to represent the additional surface. The object must overlap the slab.
  2. Select both the slab and the add surface object.
  3. Select Modify > Add Surface.
The Add Shape to Slab dialog box opens.
Clipping a Slab
When clipping, or subtracting from, a slab, select whether the clip operation should affect the entire slab or only certain components.
To clip a slab:
  1. Create a closed 2D object to represent the clipping object. The object must overlap the slab.
  2. Select both the slab and the clipping object.
  3. Select Modify > Clip Surface.
  4. The Clip Shape from Slab dialog box opens.
Changing the Slab Modifier
Editing Slab Geometry with 3D Modifiers
