Spot00051.pngInserting House Rigging Points on Selected Objects
Command
Path
Insert House Rigging Point at Selection
Spotlight > Rigging
The Insert House Rigging Point at Selection command inserts a house rigging point on each selected object.
To insert house rigging points on selected objects:
  1. Select the objects, such as support beams, and select the command.
  2. The Select Symbol dialog box opens.
  3. Select a house rigging point symbol from the Resource Selector.
A house rigging point is inserted on each selected object.
Inserting Mother Grids
Inserting Bridles
