Tool |
Tool set |
Hoist
Rigging |
The Hoist tool and the Insert Dead Hang tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
An alternative, simpler way of inserting drops is by Placing Dead Hang Objects.
The Hoist tool places the hoists in the drawing.
To place a hoist in the drawing:
Click the tool.
Click in the drawing to place the hoist.
The first time you use the tool in a file, a properties dialog box opens. Set the available default properties (some properties are set automatically based on the selected symbol). The properties can be edited from the Object Info palette.
Using Auto Connect technology from Braceworks, when placing the hoist preview over an existing valid structural object such as a truss, the hoist insertion point is highlighted to indicate that when it is placed there, the hoist is automatically connected to the structural system.
The hoist’s graphical representation in Top/Plan view depends on whether the hoist motor is up or down, as well as its load rating and its manufacturer or function. Hoist symbols, which can be customized, are available in the Vectorworks Libraries\Defaults folder; a selected hoist symbol is automatically imported into the current file and displays in the Resource Manager; see Resource Manager. The display of the hoist number, dimensions, and labels can be adjusted from the Object Info palette, and with the Set Hoist Number and Dimension Display command, or by making the associated number or label class invisible.
Number the hoists so that they have unique IDs in reports and calculations (Braceworks required).
After placement, hoists can be selected based on Object Info palette categories like the function, location, and type with the Select Hoists command.
Click
to show/hide the parameters.
