DesignSeries00014.pngMapping IFC Data
Command
Workspace: Path
IFC Data Mapping
●        Architect: AEC
●        Landmark: Landmark > Architectural
●        Spotlight: Spotlight > Architectural
In a BIM project, you may wish to control whether specific objects and symbol definitions are exported to IFC. The property sets of specific objects can also be controlled prior to export, so export filtering can occur at the object or property set level. In addition, external data attached to objects may need to be mapped to their IFC equivalent prior to export. You can define, save, and restore multiple custom mapping sets for a document. Selected IFC object instances can use or not use the mapping.
Here are some examples of when IFC data mapping is useful.
●        You need to add data to an object’s default IFC assignment.
Mapping allows you to attach property and data set information to objects in addition to the default IFC data. Many Vectorworks objects contain user-defined data that is not included as part of the default IFC assignment. For example, a type designation or acoustic rating for a door is user-defined data within the door object. These parameters can be mapped to the corresponding IFC parameter values.
●        You need to map data from a custom record format to an IFC property set.
In Vectorworks, custom data is attached to objects (default objects, plug-in objects, and custom modeled objects) using record formats. The parameters of a custom record format can be mapped to the correct, corresponding IFC property set. For example, a local code or specification system may be attached to an object through a custom record. The parameters for these records can be mapped to the identified, IFC Classification data set to ensure that the data is transferred during an IFC model exchange.
●        You need to attach a default IFC assignment and property sets to custom modeled objects or symbols.
IFC assignments and property sets can be defined for all custom-made objects, ensuring that each time the custom object is placed in the file, it will receive the appropriate IFC tag assignment.
To map IFC data:
  1. Select the command.
  2. The IFC Data Mapping dialog box opens.
  3. Assign IFC data to any objects or symbol definitions that do not have any, set objects and property sets that should not export to IFC, and/or define mapping formulas.
Creating or Editing Mapping Formulas
Using Custom IFC Property Sets
IFC Data Mapping Expressions
IFC Data Mapping Examples
Validating IFC Data Mapping
