Spot00046.pngDisassociating Load Objects from a Hanging Position
Load objects can be removed from their association with a hanging position.
Removing a Single Load from its Hanging Position
Command
Path
Remove from Hanging Position
Context menu (drop-down)
To disassociate a single load object from its hanging position:
  1. Select the load’s associated hanging position.
  2. Select the command.
Removing Multiple Loads from a Hanging Position
Command
Path
Remove Loads
Context menu
To disassociate one or more loads from a single hanging position:
  1. Right-click on the hanging position, and select the command.
  2. Valid load objects are highlighted as the cursor moves over them.
  3. If a load has multiple components associated with the hanging position, select which component to disassociate. Hover the cursor over the desired component.
  4. The selected component displays a cross, indicating that it is the component to remove.
  5. Click a load to disassociate it from the hanging position.
  6. Press the Esc key or click on the Selection tool to stop removing loads.
Concept: Hanging Positions and Associated Loads
Associating Load Objects with a Hanging Position
Editing Associated Loads
