Command |
Path |
Edit Vision Data |
Spotlight > Visualization |
Vectorworks Spotlight software is integrated with the Vision program, for lighting devices that have an appropriate Fixture Mode setting. Associated with the fixture mode, default data for Vision specifies the device’s color wheels, gobo wheels, animation wheels, and attachments; the default Vision data can be changed for a selected lighting device with the Edit Vision Data command.
The gobo, color, and animation properties of the instrument can either be set here, or by clicking Edit from a selected lighting device. General and attachment information can only be set from the Edit Vision Data command.
Vision must be installed to specify Vision data with the command.
To edit Vision data:
Select a lighting device with a Fixture Mode supported by Vision. Check for Vision availability from the Fixture Mode dialog box (see Selecting a Fixture Mode).
Select the command.
The Vision Light dialog box opens.
Click
to show/hide the parameters
