Mode |
Tool |
Tool set |
Modes for the Polyline Tool |
Lighting Pipe
Rigging |
Insert and configure a lighting pipe object with the Lighting Pipe tool.
For Braceworks calculations (Braceworks required), the lighting pipe is considered to have a rigid cross section.
To insert a lighting pipe object:
Click the tool and mode.
Alternatively, create a polyline and then select the Create Objects from Shapes command (see Creating Objects from Shapes).
Click in the drawing area to begin drawing the lighting pipe.
To draw a multi-segment pipe, click to set the end of one segment and start the next.
Create a curved pipe by changing the vertex type (see Creating Polylines).
Double-click to complete the lighting pipe polyline.
Click
to show/hide the parameters.
