Duplicating Objects Along a Path
Command
Path
Duplicate Along Path
Edit
The Duplicate Along Path command creates and places several copies of an object or objects along an existing path.
If a 2D object and 3D path are selected, the 2D object is projected onto the path.
To duplicate objects along a path:
  1. Select the object or objects to duplicate, and select the path object.
  3. Select the command.
The Duplicate Along Path dialog box opens.
Making a Duplicate
Duplicate Array
