Add Solids
Command
Path
Add Solids
●        Model
●        Context menu
The Add Solids command joins two or more 3D objects into a single solid object.
To add solids in 3D:
  1. Select two or more 3D objects to combine.
  2. Select the command.
A single solid object is created from the objects.
Editing 3D Solids
Editing 2D Object Surfaces
