Intersect Solids
Command
Path
Intersect Solids
●        Model
●        Context menu
The Intersect Solids command creates a single solid object from the volume created where two or more 3D objects intersect.
To intersect solids:
  1. Select the two or more 3D objects to combine.
  2. Select the command.
A single solid object is created from the 3D objects; it is the size and shape of the overlapping volume of the selected objects.
Editing 3D Solids
Editing 2D Object Surfaces
