Importing Resources
Use the import function of the Resource Manager to import one or more resources or resource folders from any file to the active file, without opening the source file.
To import resources or resource folders:
  1. From the Resource Manager’s file browser pane, select any file other than the active file.
  2. Select one or more resources or resource folders to import.
  3. Right-click on the resource/folder, and select Import from the context menu.
  4. The Import Resource(s) dialog box opens.
  5. If the active file already contains a different resource with the same name, you are prompted to resolve the Resource Name Conflict.
Drag and Drop Importing
A fast way to import is to simply drag and drop one or more resources from any file or folder to the active file in your Open Files list.
Searching for a Resource
Using Resources in Your Drawing
Resource Manager
