Command |
Path |
Spotlight Preferences |
File > Document Settings |
The options on the Lighting Device tab enable automatic positioning, assign classes, and specify attributes of the lighting devices in the file. The parameters selected can have a powerful global effect on all the devices, both existing and new.
Lighting instruments and other loads can be automatically associated with a hanging position, both at insertion and when an existing load is moved on the light plot. Throughout the design work, particularly in the later stages, instruments may need to be moved slightly, but they should not be accidentally associated with a different nearby hanging position. Auto positioning provides the necessary control over the automatic association of load objects with hanging positions.
Class and color assignments for lighting instruments allow the designer to:
● Assign the lighting instruments to a specific class, or to one or more classes determined by an instrument parameter.
● Control the color of lighting instruments, or parts of instruments, by gel color or from the Attributes palette.
● Control the wireframe light beams, angles, and centerline of lighting instruments by class.
● Control the label legend container appearance by class.
● Control the appearance and visibility of lighting instruments in viewports, when using viewport overrides.
The Object Info palette display of lighting device parameters can also be set from this tab.
To specify lighting device preferences:
Select the command.
The Spotlight Preferences dialog box opens. Click the Lighting Device tab.
Click
to show/hide the parameters.
Specify the auto-positioning and appearance settings for the file’s lighting devices.
Click Save as default to use the lighting device and other Spotlight settings for other files created with the Vectorworks Spotlight product.
Class setting changes require confirmation before regenerating the lighting devices.
