Mode |
Tool |
Tool set |
Move Face
Push/Pull
3D Modeling |
The Move Face mode extends the face of a solid, extruding the surrounding or adjacent geometry as the face moves.
To move the face of a solid in Move Face mode:
Click the tool and mode.
Click the desired planar face.
If needed, the Select Face dialog box opens to help select the correct face, as described in Selecting the Edges and Faces of a Solid. To select the back faces of solids, press the Alt key (Windows) or Option key (Mac) while selecting.
The cursor changes to a double-headed arrow. Move the cursor to extend the face and its geometry. The distance can also be specified by entering a value in the Distance field on the Tool bar or floating data bar. The new solid is previewed on the drawing.
Click at the desired location to edit the solid.
