Subdivision Modeling
Subdivision modeling allows for the easy, intuitive creation of free-form shapes, whether designing an object or exploring a concept. After creating a subdivision object or converting an existing object to a subdivision object, sculpt the model using the Edit Subdivision tool.
Creating Subdivision Objects
Command
Path
Create Subdivision Primitive
Model
To create a subdivision object:
  1. Select the command.
  2. The Create Subdivision Primitive dialog box opens.
    Alternatively, double-click the Edit Subdivision tool to open the Create Subdivision Primitive dialog box.
  3. Set the parameters. If Center at Next Click is selected, click in the drawing to place the object.
The subdivision object is ready to be edited, using the Edit Subdivision tool.
Most tools and commands that can be used to edit solid objects can be used to modify subdivision objects. However, the following tools do not edit subdivision objects:
●        Chamfer Edge tool
●        Push/Pull tool
●        Deform tool
●        Shell Solid tool
●        Extract tool
●        Taper Face tool
●        Fillet Edge tool
Converting Existing Objects to Subdivision Objects
Modeling Subdivision Objects
