DesignSeries00171.pngSending the Design to AutoTURN Online
Command
Workspace: Path
Send Design to AutoTURN Online
●        Architect: AEC > AutoTURN Online
●        Landmark: Landmark > AutoTURN Online
●        Spotlight: Spotlight > AutoTURN Online
Send your drawing file to AutoTURN Online for analysis to determine if the design has enough room for vehicle circulation. Once a file is sent to AutoTURN Online, the Vectorworks file and the AutoTURN Online drawing are linked, to easily exchange data and open associated files in the future.
If the Vectorworks file contains a polygon or polyline that determines the path for a path follow simulation, join all portions of the path poly into a single object with the Compose command before uploading the file. Other linework that represents a building or even a curb does not need to be joined.
To send your drawing to AutoTURN Online:
  1. If you are not logged in to AutoTURN Online, start by Logging In to AutoTURN Online.
  2. If you will be designating objects for uploading based on visibility, selection, or layer and class assignment, set the visibility, select the objects, or assign the objects to the appropriate layers and classes.
  3. Select the command.
  4. The Send Design to AutoTURN Online dialog box opens.
  5. Click OK.
  6. The Uploading to AutoTURN Online dialog box displays the progress of the upload.
  7. The AutoTURN browser window opens, for Working with AutoTURN Online.
  8. When finished with the analysis, either click Close and Get Analysis or Close to return to the Vectorworks drawing.
Logging In and Out of AutoTURN Online
Workflow: Conducting a Swept Path Analysis with AutoTURN Online
Simulating Vehicle Circulation with AutoTURN Online
