Land00021.pngConcept: Hardscape Fills and Joint Patterns
A single hardscape object can have multiple components, each with its own fill or joint pattern.
The hardscape can be filled with a solid color, pattern, hatch, tile, gradient, or image from the Attributes palette. See Fill Attributes for details.
For the main and border hardscape areas, different joint patterns are available.
●        Main joint patterns include flagstones and pavers, as well as hatches, stipples, and tiles that are applied independent of the Attributes palette.
●        Border joint patterns include spaced joints and the same hatch, stipple, and tile options available for main joint patterns.
If a main joint pattern is specified, it is drawn over the hardscape object fill. Both the object fill and the main joint pattern apply to the entire hardscape, unless it has a border.
Specifying Hardscape Joint Patterns
Editing Hardscape Fills and Joint Patterns
