ArchLand00001.pngCreating Stepped Walls
Command
Workspace: Path
Create Stepped Wall
●        Architect: AEC
●        Landmark: Landmark > Architectural
Stepped walls add wall peaks to existing walls created with the Wall tool or Round Wall tool. The existing wall can be a single wall or a chain of multiple wall segments that are L-joined to each other. Stepped walls can have a constant rise at each interval, or conform to underlying terrain with a variable rise, such as free-standing landscape walls or fences.
To create a stepped wall:
  1. Select the wall or multiple, L-joined walls.
  2. Select the command.
The Create Stepped Wall dialog box opens. Set the stair parameters.
The options available depend on the selected Step Style (even steps or terrain steps). If the parameters are set so that the steps are uneven, the top step is truncated.
The Send to Surface command can be used on walls; it sets the bottom Z value at the start of the wall to the existing terrain surface (see Sending Objects to the Site Model Surface).
Creating Walls
L Wall Joins
Creating Retaining Walls
