DesignSeries00024.pngEditing Existing Space Labels
You can easily make minor adjustments to an existing space label. For example, you might adjust the font style or color, or change the graphics that are included in the symbol.
To modify an existing space label symbol:
  1. Do one of the following:
  2. ●        From the Space Label pane of the Space Settings dialog box, select the label to be edited; a preview of it displays on the right side of the dialog box. Click Edit Layout to open the symbol editing window.
    ●        From the Resource Manager, right-click on the resource, and select Edit 2D Components from the context menu.
  3. In the symbol editing window, edit the text formatting, graphic components, and attributes of the symbol. Note that a space label is a page-based symbol, which means that its size in the editing window is the same as it will be when inserted into the drawing.
  4. When the changes are complete, click Exit Symbol.
  5. The symbol definition and all instances of the label in the drawing are updated automatically.
Editing Symbol Definitions
Creating Space Labels
