DesignSeries00018.pngUsing Auto-Numbering
The software can automatically number spaces as they are created, or you can enter numbers manually. If you use the auto-numbering feature, the Numbering pane of the Space Settings dialog box has additional features to customize numbers and to adjust numbers when needed.
Custom Number Styles
Tool
Tool set
Space
●        Space Planning
●        Building Shell
You can create custom space numbers that contain information other than just a counter, such as the floor the space is on, or what zone the space is in.
To create, edit, or delete a number style:
  1. Click the tool, and then click Preferences.
  2. On the Space Settings dialog box, select Numbering from the left pane to display the Numbering pane.
  3. Click Edit Number Styles to add, edit, or delete the available number styles.
  4. The Edit Number Style dialog box opens.
  5. Edit the number styles as follows:
●        To add a new number style, type a style name into Space Number Style, and add a Prefix and/or Suffix if desired. Click Save; the number style is added to the Style Name/Style Definition/Saved in list.
●        To edit a number style, select it from the Style Name/Style Definition/Saved in list and then edit the Prefix and/or Suffix as needed. Click Save to save the changes.
●        To delete a number style, select it from the list and then click Delete.
Validating Auto-Numbering
Occasionally the auto-numbering may need adjustment. For example, if a space is deleted after creation, one of the numbers will be missing from the sequence. If a space is duplicated, its number may be used twice for the same label type. The software can help you detect and correct such problems.
To validate auto-numbering:
  1. Select the space object.
  2. From the Object Info palette, click the Settings button to open the Space Settings dialog box, and then select the Numbering pane.
  3. Click Validate Auto-Numbering.
  4. The Validate Auto-Numbering dialog box opens.
  5. If there is a message next to a space number, select it and then click the correction button that displays beneath the list.
Message
Problem
Correction
missing
A number in the sequence is missing
Click Close Gaps to renumber all spaces that fall after the gap in the sequence
Value invalid (< Start)
The space’s current number is less than the start value
Click Assign valid value to automatically renumber the spaces
(multiple)
Multiple spaces have this number
Click Increase by Increment to automatically renumber the space
Space Settings
Creating Spaces with the Space Tool
