List Box Functionality
Dialog boxes that contain long lists of information (such as the Organization dialog box) may have some or all of the following functionality.
Task
Action
Change the list’s sort key
Click the heading of the column to sort by; an arrow appears on the right side of the column heading to indicate that it is the sort key
Change a column’s sort order
Click the column heading; the sort arrow in the heading indicates whether the current sort is ascending or descending
Resize a column
Click the vertical line on the right side of a column’s heading and drag it left or right
Select a group of items
Click the first item, and then Shift-click the last item in the group
Select multiple items individually
Click the first item, and then Command-click (Mac) or Ctrl-click (Windows) each additional item
Select an item on the list
Type the first letters of the desired item’s name
Edit an item on the list
Double-click the desired item
Open a context menu for an item on the list
Right-click the desired item
For lists with a Visibility column, set the same visibility for all items on the list
Option-click (Mac) or Alt-click (Windows) the desired setting
Display lists in hierarchical order
Classes can be displayed in hierarchical order (up to four levels). To enable or disable hierarchical display of classes on pop-up menus including from the Object Info palette, the View bar, and dialog boxes, see Vectorworks Preferences: Session Tab.
On the Classes tab of the Organization dialog box and the Navigation palette (Vectorworks Design Series required), display options are saved separately. See Displaying Classes in Hierarchical Order.
Application Window
