DesignSeries00068.pngInserting Symbols with the Duplicate Symbol in Wall Tool
Tool
Tool set
Building Shell
Use the Duplicate Symbol in Wall tool to easily place multiple copies of a symbol or plug-in object in a wall, such as doors or windows in an office building or electrical outlets along a wall.
Symbols can also be duplicated within walls with the Duplicate Array command (see Duplicating Symbols in a Wall with Duplicate Array) and with the Move by Points tool (see Moving Symbols in Walls with the Move by Points Tool).
The Duplicate Symbol in Wall tool has two modes.
Mode
Description
Flip
Flips the symbol during placement (for example, changes the direction that a door opens)
Standard
Places the symbol using the symbol definition’s orientation
Preferences
Specifies symbol placement information
To place duplicate symbols in a wall:
  1. Do one of the following:
  2. ●        From the Resource Manager, right-click on the resource, and select Make Active from the context menu. Alternatively, double-click the resource to activate it.
    ●        Activate a symbol already placed in the drawing with the Symbol Pick up mode of the Symbol Insertion tool (see Symbol Pick Up Mode).
    The symbol definition must have the Insert in Walls option enabled (see Creating Symbol Definitions).
  3. Click the tool.
  4. Click the placement mode.
  5. This sets the symbol orientation. To place the symbol using the orientation from the symbol definition, click Standard mode. To flip the symbol when it is placed, click Flip mode.
  6. Click Preferences.
  7. The Duplicate Symbol In Wall dialog box opens. Indicate how to place the symbols.
  8. Click the wall to indicate where the first symbol should be inserted. A preview of the symbols are shown along the wall to aid in placement. If inserting the first symbol by an offset value, click anywhere on the wall and the first symbol preview displays at the proper offset distance.
  9. If spacing symbols by the next mouse click, move the cursor along the wall to set the spacing between symbols, and click again to insert the duplicate symbols. If spacing symbols by a specified distance, click again to insert the duplicate symbols. If a number of copies is specified, that number of symbols is automatically inserted.
Move the cursor to the opposite side of the wall to flip the symbol direction.
Moving Symbols in Walls with the Selection Tool
Moving Symbols in Walls with the Move Command
Symbols Within a Wall
