Modifying Viewports
Command
Path
Edit Viewport
●        Modify
●        Context menu (Edit)
There are various ways to modify viewports; their appearance can be completely different from the original design layers, for presentation purposes.
Modification
Description
Change the settings for the viewport in the Object Info palette
Viewport Properties
Modify the viewport with various 2D and 3D tools and commands
Moving and Editing Viewports
Add annotations and dimensions to the viewport
Creating Annotations for Sheet Layer Viewports
Crop the viewport
Cropping Existing Sheet Layer or Design Layer Viewports
Edit one or more design layers in a live section or elevation
Editing Design Layers from a Section or Elevation View
Edit a design layer displayed in the viewport
Editing a Design Layer Displayed in a Viewport
Edit or delete a linked Renderworks camera
Editing a Linked Renderworks Camera
Change the properties of the viewport’s layers and classes
Changing the Layer Properties of Sheet Layer or Design Layer Viewports and Changing the Class Properties of Sheet Layer or Design Layer Viewports
Change the attributes of the objects in the viewport based on their attached record formats
Viewport Data Visualization
To modify a viewport:
Select the viewport and select the command. The Edit Viewport dialog box opens. The options available depend on whether the viewport is on a sheet layer or design layer (Vectorworks Design Series required).
Modifying Section Viewports and Section Lines
Overriding Viewport Display
Viewport Status
Updating Viewports
