Using Multiple Drawing Views
Command
Path
View bar
Enable Multiple View Panes
View > Multiple View Panes
To use multiple drawing views:
  1. In any drawing view, select the command or click the View bar button.
  2. The drawing area is divided into multiple view panes; the single view when the command is selected becomes the active view.
  3. To set all panes to the same class visibilities, layer visibilities, and clip cube, select View > Multiple View Panes > Use Same Visibilities in All Panes. Deselect the command to set visibilities independently in each view pane.
  4. Edit the drawing in the active view pane; to configure and draw in a different pane, click in the pane or on the pane title flag to make it active.
  5. You can begin a drawing operation in the active pane and conclude it in another pane.
  6. To return to a single view pane, select the command again.
Concept: Multiple Drawing Views
Changing the Multiple View Pane Layout
