DesignSeries00055.pngCreating Wall Components
Wall components define the sections that make up a standard wall. For example, to indicate that a wall is made up of studs, inner drywall, outer sheathing, and then a siding material, define a component for each of these items to illustrate their location. Wall components can be offset at the top or the bottom of the wall, individually constrained relative to the wall, the layer, or, for Vectorworks Architect users, to story levels. Components can be textured, creating realistic section views and rendered views, as well as accurate wall material estimates. The area and volume of wall components can be calculated in worksheets; see Worksheet Functions.
The overall thickness of a wall is equal to the sum of its components. Component fill and pen style are only displayed in Top/Plan view (except for section viewports).
Use the Eyedropper tool to copy wall component settings from one wall to another (see Transferring Attributes).
Curtain walls do not have components.
Wall components can be defined prior to drawing by clicking the Preferences button or after drawing the wall, from the Object Info palette.
Wall components can also be edited from the Wall Preferences dialog box. Editing a component from wall preferences does not affect existing walls.
Defining Components for New Walls
Tool
Workspace: Tool set
Wall
●        Architect and Spotlight: Building Shell
●        Landmark: Building Shell and Site Planning
To define a wall component prior to drawing the wall:
  1. Click the tool, and then click Preferences.
  2. The Wall Preferences dialog box opens.
  3. On the Definition tab, click New.
  4. The Wall Component Settings dialog box opens. Specify the component thickness, name, and parameters.
  5. Click OK to create the component and return to the Wall Preferences dialog box.
The wall’s Overall Thickness value changes to be determined by its components. As components are defined, they display in the preview. Click and drag a component in the # column to change its order.
Defining Components for Existing Walls
To define or edit wall components for an existing, unstyled wall, or to edit the components’ top and bottom heights for styled walls:
  1. Select the wall.
  2. From the Object Info palette, click Components.
  3. The Wall Components dialog box opens.
  4. Click New or Edit, and define or edit the components as described previously.
The Attributes Palette
Joining Wall Components
Energos Energy Analysis Module
Concept: Applying Textures by Class to Objects and Components
