DesignSeries00103.pngCreating Wall Recesses
Command
Workspace: Path
Create Wall Recess
●        Architect: AEC
●        Landmark: Landmark > Architectural
●        Spotlight: Spotlight > Architectural
To create a wall recess:
  1. Create the closed 2D or 3D solid object with which to modify the wall. The geometry of the object must define an area or volume that has no self-contacts, no self-intersections, and no edges that fold back on themselves.
  2. For a 2D object, simply make sure that the object overlaps the wall in Top/Plan view. For a 3D object, first create the object at the appropriate height in relation to the bottom of the wall (Z axis); then set the appropriate X and Y axis location so that the object overlaps the wall.
  3. With both the appropriate wall and the modifier object selected, select the command.
Alternatively, for 2D objects only, select Modify > Clip Surface.
The Create Wall Feature Recess dialog box opens; different fields display depending on whether a 2D or 3D modifier object is selected.
Creating Wall Projections
Wall Feature Properties
Editing Wall Features
Creating Wall Features
Creating Walls
