DesignSeries00033.pngCreating Wall Styles
Tool
Workspace: Tool set
Wall
●        Architect and Spotlight: Building Shell
●        Landmark: Building Shell and Site Planning
To create a wall style:
  1. Click the tool, and then click Preferences.
  2. The Wall Preferences dialog box opens.
  3. To modify an existing wall style, select the Wall Style from a library or the current file. Alternatively, select Unstyled as the wall style and set the parameters.
  4. Specify the wall and component parameters as described in Drawing Straight Walls.
  5. Click Save Preferences as Wall Style.
  6. The Assign Name dialog box opens.
  7. Enter a unique name for the wall style.
  8. If the wall style name already exists, you are prompted to cancel and select a different name, or replace the existing wall style with the edited wall style, for all walls that use that style. If you are replacing wall styles, the Wall Replacement dialog box opens; specify the wall alignment properties.
  9. The new wall style is saved with the file and displays in the Resource Manager and Resource Selector, as well as the Wall Style list on the Tool bar.
You can also use the following methods to create a wall style:
●        Right-click on an unstyled wall, and select New Wall Style from Unstyled Wall from the context menu.
●        From the Resource Manager, click New Resource, select Wall Style, and then click Create.
Concept: Resource Libraries
Editing Wall Styles
Applying Wall Styles
Deleting and/or Replacing Wall Styles from the Resource Manager
Replacing Wall Styles from the Object Info Palette
