DesignSeries00138.pngCreating Columns and Pilasters
Mode
Tool
Workspace: Tool set
Modes for  The Symbol Insertion Tool
Column
●        Landmark, Spotlight: Building Shell (basic column)
●        Architect: Building Shell (additional capabilities)
Pilaster
In the Vectorworks Architect product, columns and pilasters can be architectural in nature, structural in nature, or both. Use the Column tool or Pilaster tool to draw an object that not only reflects the architectural appearance of a column/pilaster, but also defines it in structural terms that can be used in an engineering analysis of the building. Structural and architectural elements can be displayed or hidden. The column ID can also, optionally, be placed on the drawing. Additionally, in the Architect product, the column/pilaster can be exported to IFC format for exchange with structural analysis programs.
A pilaster can be placed in a wall (however, a column cannot be placed in a wall). A pilaster inserted in a wall can set its architectural height relative to the wall.
To create a column or pilaster:
  1. Click the tool and the desired symbol insertion and alignment modes.
  2. From the Tool bar, click either Active Def to select an existing resource from the Resource Selector, or click Preferences and set the default parameters to create a custom object.
  3. Click on the drawing to place the object, and click again to set the rotation. The properties can be edited from the Object Info palette.
To create a circular or square shaft, capital, or base, enter the same value for the width and depth.
Optionally, after placement you can create a plug-in object style, which combines style parameters (with a fixed value established by the style) and instance parameters (which can be set independently for each instance of the styled object in the drawing). See Creating Plug-in Object Styles.
Basic Column Parameters
The basic column object is available with the Vectorworks Landmark and Spotlight products.
Arch00142.pngArchitect Column and Pilaster Parameters
The architectural column and pilaster objects are available with the Vectorworks Architect product.
Exporting Columns and Pilasters to IFC Format
