The active planes list
On the View bar, the Active Planes list displays the currently active plane, and also allows other active planes to be selected. The available planes depend on the drawing view, current tool, presence of named working planes, and plane mode options.
Plane
Description
Automatic
The active working plane changes as the cursor moves over the drawing area in a 3D view. The automatic plane is a temporary working plane that does not need to be set; over suitable surfaces and with certain drawing tools, the automatic plane is planar to the surface. Otherwise, the automatic plane aligns to the layer plane.
Layer Plane
The active working plane is planar to the current plane of the active layer
Custom Plane
The active working plane is planar to a saved working plane position; selecting a working plane cancels the automatic working plane.
Screen Plane
The active working plane is aligned to the screen plane (planar to the computer screen)
Screen Aligned
The active working plane is parallel to the screen plane in the current orthographic view
Options
Opens the Document Preferences dialog box, for setting the plane mode options; see Document preferences: Plane Mode tab
Concept: Understanding the working plane
Concept: The automatic working plane
Concept: Objects in the screen plane and in the layer plane
Appearance of the planes
Setting the working plane location
Manipulating the working plane
The working planes palette
Aligning objects to the working plane
