The design of rigging structures is an integral part of the event, entertainment, display, and exhibit industries. The Braceworks® suite of commands and tools inserts and connects supporting structures (such as trusses and lighting pipes), adds hoists and other supports, and then adds loads to the structures.
With a Braceworks license, the system uses Finite Element Analysis (FEA) to accurately calculate and analyze the structural forces of a hanging rigging system, to determine whether the structural system is viable. Structural reports and the ability to export in DSTV or SCIA format allow the calculations to be shared and validated by structural engineering colleagues.
Vectorworks Spotlight incorporates many of the Braceworks features for drawing rigging structures and adding loads, allowing Spotlight users to take advantage of the rigging tools and run a system check (a Spotlight user may need to add the available commands to the workspace).
However, a Braceworks license is required to perform calculations and create reports.
The structural analysis calculations in Braceworks are done by an FEA core that performs calculations upon the rigging objects in the Vectorworks drawing (the truss, straight truss, curved truss, lighting pipe, and lighting pipe ladder). Each object is handled individually in the calculations; the FEA core considers the hinge trusses as joints and all other truss, pipe, and ladder elements as beams. To determine the correct type of beam or joint, each contains the cross section information required for proper calculations.
The following commands require a Braceworks license:
● Calculate All Objects |
● Export Braceworks Structure |
● Calculate Load Combinations |
● Create Calculation Report |
● Calculate Visible |
● Calculation Overview |
● Calculate Selection |
● Scale Influence Lines |
In conjunction with Spotlight’s other tools and commands and features, lighting designers can use Braceworks tools as part of the design process, and rigging professionals can use the Braceworks tool set and commands to create, analyze, and report complete rigging designs. The suggested workflow will vary, depending upon the type of design, the venue, the event, and whether you have a Spotlight or Braceworks license.
Lighting designers planning to use Vision to previz a show can set up a file with Braceworks with little change to their current workflow. To reduce excess geometry, use the Insert Truss, Straight Truss, and Curved Truss tools as well as the Lighting Pipe and Lighting Pipe Ladder tools to insert rigging objects. Lighting devices and other loads can attach directly to these objects. The Convert to Hanging Position command creates custom hanging positions from multiple rigging objects or other geometry.
● Collaborate with all departments involved with rigging.
● Specify the basics of the drawing, such as establishing the layer scale, creating layers, setting up Spotlight preferences, and so on. Create non-rigging elements for the drawing (stage objects, venue walls).
● Optional: Set up the truss inventory with the truss types and different truss lengths available, by selecting the Replace Truss command and clicking Truss Inventory.
● Define the Braceworks preferences.
● Create the rigging structure in the drawing space. Insert trusses with the Insert Truss tool. Auto Connect mode should be enabled so that the rigging elements create a system. Alternatively, use the Straight Truss tool and/or the Curved Truss tool. Insert lighting pipes with the Lighting Pipe tool and lighting ladders with the Lighting Pipe Ladder tool.
Braceworks treats the hinge trusses as joints, and the other trusses, pipes, and ladders as beams.
● If needed, add connections between structural elements. The Insert Connection tool creates hoists, dead hang objects, or truss cross connections between trusses.
● If bridles are needed, define the available rigging points with the Insert House Rigging Point tool, the Structural Member tool, and the Insert Mother Grid tool.
● Use the Convert to Hanging Position command to group structural objects into a single hanging position for lighting devices and other loads.
● If needed due to inventory restrictions or other requirements, replace parts of the truss line with different lengths of truss with the Replace Truss command, or replace one truss type with another with the Replace Truss Type command.
● Add, or have the various departments add, the load objects such as lights, speakers, video screens, and so on, or insert a point load or distributed load with the Insert Load tool. The auto connect function snaps the load to the correct point. Loads are attached to rigging objects automatically, or can be attached later. Any elements that are not needed for calculations (Braceworks required) should be kept on layers that are separate from the elements that will be calculated.
● Use the Insert Drop command to connect structural elements by hoists or dead hang objects, or use the Hoist tool and Insert Dead Hang tool to suspend the system.
Number the hoists so that they have unique IDs in reports and calculations.
● Insert bridles, and adjust their configurations, to support the truss system.
● Run the system check commands (first on selected, and then on all objects) to find any mistakes, such as unattached loads or hoists, and misaligned or unsupported objects.
● Braceworks required: Correct any mistakes found. Braceworks provides color-coded annotations to assist with this, both in reports and within the drawing.
● Braceworks required: Hide the layers that do not participate in calculations, and then run the calculations first on a subset with the Calculate Selection command, and then on all visible items with the Calculate Visible command.
● Braceworks required: Run the calculations on all rigging objects with the Calculate All Objects command to determine the viability of the system.
● Make changes to the system as needed.
● Create schematic views from the rigging objects.
● Braceworks required: Create a report of the calculations.
● Braceworks required: Export reports if needed, sharing the data (PDF, DSTV, or SCIA file) with structural engineers, colleagues, or clients.
