Completed calculations can be shared with colleagues, clients, and structural engineers by creating a customized PDF report, or by exporting the calculation results to DSTV or SCIA format.
Command |
Path |
Create Calculation Report |
Braceworks |
A comprehensive report of the calculations can be generated as a PDF file.
To create a calculation report:
1. Select the command.
The Create Calculation Report dialog box opens. Cycle through each pane in order with the <Back and Forward> buttons to create and customize a complete report.
The system must be solvable to be able to create a report.
2. When all items in each pane have been addressed, click Create PDF to create the report. Provide a name and location to save the file.
