Set up cable preference settings prior to creating cables.
Command |
Path |
Cable Preferences |
Spotlight > Cables |
The Cable Preferences command sets default cable lengths and offset distances.
To set up cable preferences:
Select the command. The Cable Preferences dialog box opens.
Click
to show/hide the parameters.
Command |
Path |
Circuit Assign Preferences |
By default, the Assign Multicable Circuits command assumes that the multicable circuit information is to be assigned to lighting devices. However, there are other situations where multicable information needs to be assigned to speakers or other types of stage objects. The Circuit Assign Preference command determines how to assign values to objects that are not lighting devices.
To set up multicable circuit preferences:
Select the command. The Circuit Assign Preferences dialog box opens.
Click
Command |
Path |
Multicable Jumper Preferences |
The Multicable Jumper Preferences command determines default placement options when placing multicables with jumper cables.
To set up multicable jumper preferences:
Select the command. The Multicable Jumper Preferences dialog box opens.
Click
