Animations of models can be viewed within Vectorworks, or they can be saved as a movie file that can be sent to partners and clients, and included in presentations and online.
1. Set the class and layer visibilities as needed for the movie.
2. Select the animation path object from which to create a movie.
To access a previously created animation path in a drawing, select it from the Cameras tab of the Visualization palette.
3. Do one of the following:
● Click Create Movie in the Object Info palette.
● Right-click on the animation path object and select Create Movie from the context menu.
The Create Movie dialog box opens.
4. Click Save Movie to save the animation.
The Select Movie Filename dialog box opens.
5. Specify the name, location, and file type for the movie file.
A .mov (MPEG4) file with H.264 compression is created. Windows-generated and Mac-generated movies can be viewed on either platform. Simply double-click the file to open it, or open it from your preferred viewer.
Multiple movies can be stitched together using a third-party video editing program to create a more extensive walkthrough of an entire model, or to create a fading transition between scene changes.
